If your motherboard supports it, could you upgrade the microprocessor? Or, if not, upgrade the motherboard and CPU?
I haven't seen this suggested anywhere, but you may then be able to boot into Windows (does anyone know if this will work)?
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
Anders
Just a caution. On the fx- nnnn systems, if you are using mother board utilities for things like fan control, you may wish to see if those utilities are working and that you are getting sufficient cooling.
See here.........
Like I said, just a word of caution.
MELERIX
Disabling Virtualization seems reasonable, most reasonable. My AM2 system is currently powered off in a "Not Bricked" or better said "Not Bricked again Yet" state.
I am trying to find a workaround (blowout patch) that is better than the 6 or 35 day thing. It would sure help things out until there is a fix.
This PC doesn't seem to want to do the rollback thing so I appear to be stuck with "Refresh your PC" .
It's about a two and a half hour cycle time. Doing a lot of reading to try to get the most out of each cycle.
I did see that Jaroslav attempted this and it did not help, however it was attempted as recovery from the failed "Bricked" state.
Could you elaborate on the idea of turning off Virtualization and / or HPET or why that may be worth a try and possibly modify the install if turned off in the "Not Bricked again Yet" state.
AMD X2 +4600 has the same issue.
Adding my bricked Pavilion machine with AMD Turion X2 processor to the list. Was able to get it backup restored and running again but have had to disable WU service to ensure the problem doesn't come back. Might try the show/hide fix later but would like to see a true fix as soon as one can be found.
