Same problem as everyone else. AMD 64 Athlon X2
After installation of KB4056892 boot failure, after roll-back error 0x800f0845
I have older AMD Athlon 64 X2 6000+, Asus MB, after installation of KB4056892 the system doesn't boot, it only shows the Windows logo without animation and nothing more. After several failed boots it do roll-back then it shows error 0x800f0845. Unfortunately, it seems it's not easy to disable the automatic updates without gpedit tweaks, so it tries installing and rolling-back the update over and over. The sfc /scannow shows no problem, in-place upgrade also doesn't seem to help. I can try full reinstall, but I doubt it will change anything. It seems like the update is binary incompatible with my old CPU. I understand that making the machine unbootable is the best protection from remote exploitation, but I would rather have the OS working. Especially if my CPU is not vulnerable to the Meltdown attack and the MS mitigation attempts for Spectre is more than questionable. I could find only some German and Italian people reporting the same issue (well the CPU is quite pre-historic and the KB update is very fresh), but no info / acknowledgment from the MS so far. I have Czech localization. Could anybody provide more information?
2018-01-08T17:36:54+00:00 -
2018-01-08T17:37:40+00:00 Hi!
The update KB4056891 (version 1703) is affected too, it causes the same problems as KB4056892 by version 1709.
Regards
Roman
DualCore AMD Athlon 64 X2, 2800 MHz (14 x 200) 5400+, KB4056891 - brick... Restored from restore point. -
2018-01-08T18:10:29+00:00 We are currently running through an investigation regarding the error code 0x800f0845 being received after installing the KB4056892 update.
Please wait for further announcements for the fix. In the meantime, we strongly encourage everyone to send a feedback to us using the Feedback Hub.
One more thing: the Feedback Hub is not working in my Windows. I receive message: "An error occured". And how can I leave there any feedback???
2018-01-08T18:12:00+00:00 Hi everyone,
You can either vote on an existing submission or submit a new issue. When you submit a feedback item, we gather additional details and information about your issue that will help us in determining the cause and to be able to address it. Feedback items regularly receive Microsoft responses on the submissions in the Feedback app so you can see what we are doing about your feedback. Please re-visit frequently to see the status of your feedback items.
You can follow these steps in submitting a new feedback:
- Search for Feedback Hub in the Cortana search field, then click the app.
- Click Feedback found at the upper-left part of the window, then press + Add new feedback.
- Tick Problem, share any details you think are relevant, then choose an appropriate category and subcategory.
- Important: If possible, reproduce the problem(s) after clicking Begin monitoring (or Start capture) near the end of the form; Stop monitoring when you're done.
- Click Submit once you've completed the form and monitoring.
- Click Continue using Feedback Hub.
- Click My feedback at the top, then find the item you have submitted (it may take a while to appear).
- Open the item you have submitted, then click Share.
- Click Copy link, then paste the link here in your response (it will look like https://aka.ms/<unique link>).
We appreciate your patience regarding this matter.
If you have other queries, feel free to create a new post.
Regards.
hopefully this helps find a solution. https://aka.ms/D1xb5w
2018-01-08T18:16:55+00:00 hopefully this helps find a solution. https://aka.ms/D1xb5w
Feedback Hub is still not working, even with this link. ERROR!
