Volume bar won't go away/volume stuck at 100
2017-12-22T00:30:06+00:00
For the past 6 days the volume bar has not gone away. I try to turn down the volume, but it gradually goes back to 100. The bar gets in the way, and the volume is way too loud. I've seen other people have had this same problem, but I haven't found a solution. I've restarted my computer, I've downloaded an updated audio driver, I've held down the audio buttons on my keyboard, but nothing helps.
I have a Windows 10, Inspiron 15-7579, 64 bit.
[Moved from: Windows / Windows 10 / Performance & system failures]
2018-03-28T02:42:52+00:00
I just searched the interned for hours only to discover that it's not a software issue, but that there is a volume button on the side of the computer next to the power that I never noticed and it was STUCK. That was definitely my problem. It's still kind of stuck for me, but at least the volume icon went away. Hope this helps.
Ryan
74 additional answers
    2018-12-29T03:41:12+00:00
    TNRC51, love your work.  Your reference to the wireless keyboard jolted my memory that my wireless mouse needed recharging and as sure as hell as soon as I plugged it in....problem gone.  Thank you
    2019-01-21T23:37:38+00:00
    Use the function keys on the top of the device keyboard . I pressed Esc, F1 , F2, F3, F4 , F5 in sequence and the volume bar went away. I tried to get it back but it did not come back . I do not miss it though but felt great to get rid of it. Happy computing guys.
    2019-02-02T18:35:06+00:00
    Thanks for the message, I experienced similar issue and seems to be resolved now by manipulating side volume key on laptop (it seemed to be stuck).
    Keep up the good work.
    2019-02-02T18:37:13+00:00
    Ryan
