Volume bar won't go away/volume stuck at 100
2017-12-22T00:30:06+00:00
For the past 6 days the volume bar has not gone away. I try to turn down the volume, but it gradually goes back to 100. The bar gets in the way, and the volume is way too loud. I've seen other people have had this same problem, but I haven't found a solution. I've restarted my computer, I've downloaded an updated audio driver, I've held down the audio buttons on my keyboard, but nothing helps.
I have a Windows 10, Inspiron 15-7579, 64 bit.
[Moved from: Windows / Windows 10 / Performance & system failures]
2018-03-28T02:42:52+00:00
I just searched the interned for hours only to discover that it's not a software issue, but that there is a volume button on the side of the computer next to the power that I never noticed and it was STUCK. That was definitely my problem. It's still kind of stuck for me, but at least the volume icon went away. Hope this helps.
Ryan
74 additional answers
    2020-08-20T06:02:24+00:00
    My sound icon is stuck at 67%  Can someone help me please
    2020-08-20T17:55:36+00:00
    Have you taken apart your computer before?
    2020-11-05T21:36:40+00:00
    I had the same problem and it was due to my Logitech MX Keyboard. I switched it to another device and managed to adjust the volume with the mouse. Then I reconnected the keyboard to the Windows device and it stopped topping the volume to 100%.
    Almost certainly there is a software issue with the Logitech MX Keyboard driver.
    2020-12-12T02:41:48+00:00
    Thank you so much Ryan! This was the first post I stumbled upon so you probably saved at least an hour of my life haha
