Volume bar won't go away/volume stuck at 100
2017-12-22T00:30:06+00:00
For the past 6 days the volume bar has not gone away. I try to turn down the volume, but it gradually goes back to 100. The bar gets in the way, and the volume is way too loud. I've seen other people have had this same problem, but I haven't found a solution. I've restarted my computer, I've downloaded an updated audio driver, I've held down the audio buttons on my keyboard, but nothing helps.
I have a Windows 10, Inspiron 15-7579, 64 bit.
[Moved from: Windows / Windows 10 / Performance & system failures]
2018-03-28T02:42:52+00:00
I just searched the interned for hours only to discover that it's not a software issue, but that there is a volume button on the side of the computer next to the power that I never noticed and it was STUCK. That was definitely my problem. It's still kind of stuck for me, but at least the volume icon went away. Hope this helps.
Ryan
74 additional answers
    2020-01-19T13:42:59+00:00
    Thanks for your solution; exactly the same issue here with my Logitech keyboard on which I spilled Coca Cola in the past! :-)
    Thanks!!!!!!!!!!
    2020-01-30T21:54:01+00:00
    Here's yet another possible solution. To get rid of the annoying volume bar from the upper left hand corner, I just pressed "Fn" on my PC Acer Laptop keyboard while holding down the right cursor arrow to change it from volume to bright, and voila, the display disappeared!  It's fine now, even after I toggled it back to volume display!
    Hopefully, this saves some of you aggravation!
    CHEERS! :)
    2020-02-28T18:34:23+00:00
    This is brilliant and sad at the same time. I've been looking for a solution for hours to this before stumbling on this here. Thanks.
    2020-03-01T01:04:09+00:00
    Do you mean the problem was in the keyboard attached to the laptop or the Logitech wireless keyboard?
    Yes, it was!!
    Wi-fi keyboard key was stuck. Not the laptop keyboard, as I hardly use that. It was defective from the time I received the computer!!!
