I’m seeing Trojan:JS/Flafisi.D detections and Tech Support Scams on the Edge browser Start page
2018-02-28T16:36:56+00:00
Update: A member of Microsoft's MSN Engineering Team (RodrigoLode(MSFT) has responded to acknowledge the malvertising issues associated with MSN portal. They have also requested ***" If anyone is still experiencing this, please reply here."***For more specifics on information requested please refer to the reply from Rodrigo at the following link:
https://answers.microsoft.com/en-us/protect/forum/protect_defender-protect_scanning-windows_10/im-seeing-trojanjsflafisid-detections-and-tech/8fbe8eaf-1af0-4e76-9ab0-57828f631a5f?page=7&messageId=3661a31c-2019-4808-a88b-283919038cc1
In addition to reporting the fake pop-ups themselves I would advise that you take note if there is a significant loss of performance on computer after encountering, in particular, the fake Adobe Flash Player update. If things seem sluggish you may have been subject to one of the more prevalent malicious activities known as crypto-mining/coin mining.
Invisible resource thieves: The increasing threat of cryptocurrency miners
https://cloudblogs.microsoft.com/microsoftsecure/2018/03/13/invisible-resource-thieves-the-increasing-threat-of-cryptocurrency-miners/
Especially important to report these occurrences or any other odd behaviors after using MSN website.
Moderator Edit: Provided update.
Just reading the “Comey trolls Trump” article on the Edge Start page and this pops up:
 This one was easy to handle because it was just the old-fashioned dialog loop based scam:
– but what’s coming next Microsoft?
GreginMich
[Original Title: Surprised again]
    2018-05-02T19:44:35+00:00
    we understand your frustration as we are having to "control alt delete" to stop our pc's from screaming "YOUR PC IS INFECTED! Alert, Call this number, this site is stealing your info"...  I know its not infecting the PC but it locks up Edge.
    You shouldn't be trying to hunt down these sites, the Edge team should be fixing this and it should be a #1 priority so it can't happen like with Chrome/Firefox...  You should be banging on the door of the Edge team going FIX THIS NOW.
    This is why hundreds of thousands of people leave Edge and get firefox/Chrome everyday.
    If MS doesn't care about Edge then seriously cancel it and bundle Windows with Chrome.
    It doesn't even look like MS uses Edge... its sad really.
    I've downloaded uBlock Origin to both my PC and then it automatically (SYNC?????) puts a blocker into your phone!!!!!!  (Yes, I know!!!) There are different downloads for Google, Opera, Firefox, IE etc.  They were suggested by several participants in this thread as well as the "experts" at Malwarebytes.  Biggest problem is I can't find a guide or figure out how to utilize uBlock.  I think I've adjusted some things-accidently on purpose-but basically have no clue.  I don't know what's up at Mbytes!!  They used to be very responsive.  But, like MS they have also had "personnel" adjustments.  Maybe even new owners??????
    So I'm just going to keep doing what I usually do with my PC.  Or actually, what my PC lets me do!!!!!  I foresee that it eventually will go out the window, followed by my "smartphone."
    2018-05-02T16:54:13+00:00
    It's not the same telemetry as Defender. What my team is looking at is to see the actual creative IDs that were served prior to the auto-redirect that happens. This comes from MSN owned telemetry, but digesting the historical browsed data in anonymous fashion is very expensive which is why I've been asking for some clues from users in the forms of new feedback entries.
  3. Rob Koch 26,160 Reputation points Volunteer Moderator
    2018-05-02T05:00:35+00:00
    Rodrigo,
    Is that the same telemetry data that the Windows Defender/Anti-Malware teams can provide, since I mentioned to Greg, the originator of this thread that he should suggest you contact them?
    They're obviously able to identify at least the incidents which invoke the Trojan identified in this thread, so I'd think that this might aid in narrowing those particular events down, though that also depends upon whether they can be traced back to the page which originally invoked the redirect.
    I would assume that these ads are not only being targeted at particular types of users, but also that the advertisers involved are using the same techniques that were identified by the Confiant security group in this article about the Ziconium group in January.  This allows them not only to filter for their targets, but also to avoid triggering the ads for security researchers and others trying to find them like your group.
    Uncovering 2017’s Largest Malvertising Operation – Confiant
    As a side note, I eventually realized that in my own case it's my relatively extreme privacy and other settings that allow me to avoid these completely.  Since I have the Advertising ID turned off and also normally use Internet Explorer with both tracking cookies blocked and IE Tracking protection enabled with the EasyPrivacy list, I'm an unlikely target for this type of attack.  My settings have less to do with malvertising than my own aversion to the noise that ads create, but apparently has the side effect of suppressing these type of targeted attacks as well.
    Rob
    2018-05-02T04:17:03+00:00
  5. Deleted
