Issues Updating from 1703 to 1709
2017-12-25T02:14:56+00:00
Split from this thread.
I've the same error on two older Systems which stuck on 1703 and can't get 1709.
In both cases I don't use 3rd party virus scanner, I only use Windows Defender.
Mainboard: Asus M3A78-EMH HDMI,
CPU: AMD Athlon(tm) Dual Core Processor 64 X2 4450e,
RAM: 4x1GB Samsung M3 78T2953EZ3-CF7, DDR2-800 (400 MHz),
GPU: ATI Radeon HD 3200 (Onboard)
Mainboard: Lenovo ThinkCentre M55p
CPU: Intel Core 2 Duo E6600
GPU: Intel HD Graphics 3000 / Intel GMA 3000
RAM: 2 GB
Thank you.
    2018-03-18T04:50:31+00:00
    Well, keep us informed as to the end result. You are right, that is all that matters. Maybe show us a DiskPart & BCDEdit when the dust settles. Good luck.
    2018-03-20T01:24:29+00:00
    Hi RA,
          Only way I could get a working Login was by F8 and using System Restore to get me back to a working entry.  I needed to rework all the necessary changes and for some reason the Uninstall for both Malwarebytes and SuperAnti etc where not there. this also was the case with a couple of other bits of software I had deleted and needed a reinstall to allow removal.    Windows little failures are driving me nuts.
          The on screen keyboard does not appear on my laptop.
    2018-03-20T01:43:53+00:00
    Hi All,
              I now have 16299.309 installed.   I disconnected  network locations and deleted all extra AV (Malwarebyte and SuperAnti bla bla), downloaded and ran  wu170509 .diagcab which is the Update Troubleshooter, and I do not know if it differs from the one in the Control Panel, and allowed it to do what it wanted.   I ran SFC & DISM, which did not show and problems, downloaded the "latest" image from Microsoft to run a full Upgrade Install and guess what, even after allowing the inclusion of Updates as part of the initial process I have ended up with the build before the one I am trying to Upgrade.  I wanted 16229.309 and what I got is 16299.125.  There is no information as to what the build is prior to download with the Media Selection Tool so on top of the struggle to get the B Update installed I have probably wasted time yet again on a pointless exercise because of material Microsoft seem to lazy to keep updated.
              Having blown my safety valve over obsolete images I took a few sips of my Hobgoblin and downloaded the KB4088776 Update directly and ran it.  I cannot believe that it has actually installed so I now have build 16299.309 installed!
             As info for PCR,  I did not change the Virtual Memory location or add it to C:\
    MANY THANKS TO ALL FOR YOUR ASSISTANCE.
    2018-03-20T03:48:02+00:00
    Great news. When it continued to be hopeless, you managed finally to smash right through the immovable object. So, put on some band-aids, if necessary, & best make a Windows system image backup in duplicate. 😊.
    Good luck, & keep us informed.
