SIM PIN2 to unlock mobile broadband device
2017-12-01T16:17:20+00:00
My new Laptop is a Lenovo T470s (S/N PC0PXLX1) with a "Sierra Wireless EM7455 Qualcomm Snapdragon X7 LTE-A" WWAN card.
After working well for 6 weeks, I am now unable to get an internet connection using that adapter.
Windows 10 network diagnostics tells me I need to "Enter a SIM PIN2 to unlock the mobile broadband device". I can find no way to enter anything.
Tech support at both AT&T and Lenovo have never heard of SIM PIN2 and each blames the other for the problem. I have talked to each several times and have been referred to "advanced tech support."
My internet provider is AT&T.
This community has referred to a "provider specific software" that solved one participant's similar problem.
My provider, AT&T, has given me two PUK numbers. I suspect their PUK2 may be the SIM PIN2, but I still have no way to utilize that information.
HELP!
[Moved from: Windows Insider Program / Windows Insider Preview / Install, upgrade, and activate / PC ]
    2020-07-04T08:16:05+00:00
    I have two solution either update your windows 10 or try to restore os from recovery disk.
    Though at&t is your internet provider but here error is related to software operating system so either Lenora or Microsoft can provide solution. To sim unlock pin for at&t here is the way mobile-cellphones.blogspot.com/2017/09/how-to-network-unlock-att-mobile.html.
    2020-07-17T22:56:58+00:00
    The solution is to install the newest firmware and drivers from Sierra for your broadband network-card.
    Many pc's use a windows driver for this card, and that is not working.
    Worked for my "stone-old" Fujitsu pc.
    2020-08-01T20:05:58+00:00
    same problem dell with dell latitude
    2020-08-12T02:30:48+00:00
    HELP!
    I had the same problem on my Lenovo. It was working OK and then for no reason it would not connect to internet and told me I needed to enter the SIM PIN2.
    After some time I discovered there were fixed IP addresses and subnet codes in the IP4 and IP6 settings.
    Network Connections >> right click on the Mobile adaptor >> Properties >> double click on the Internet Protocol Version 4 (TCP/IPv4) >> set to Obtain an IP address automatically.
    Leave the DNS server addresses as they are if they are in there.
    Do the same for (TCP/IPv6)
    thank you so much man I think it should be the solution for almost everyone
    now i found out why this happened to me. recently I installed a WiFi hotspot software and that changed the ip addresses and be aware that there is a lot of softwares that can cause network problems
