Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2019-10-29T12:59:26+00:00
    did you format first your os drive before installing your os? maybe some hardware are failing, like the hdd/ssd and the ram.
    2019-10-29T13:01:31+00:00
    2019-10-29T13:09:45+00:00
    my ram is fine. currently using 4gb ddr3 on h61M-K motherboard pair with i5 3570. might be my hdd. how to check if my hdd is the problem?
  4. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2019-10-31T11:06:52+00:00
    there is  a special method to solve this issues.
    see YouTube videos
