Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2019-10-29T10:52:08+00:00
    as soon as i press fixboot. it says acces is denied. What to do?
    2019-10-29T12:38:03+00:00
    doesn't work for me
    maybe the problem of the laptop I repaired is that the user shut it down while it's updating. i tried all solutions like fixboot, system restore, startup repair, and the solution is going back to earlier version of Windows.
    2019-10-29T12:40:18+00:00
    try the Advance Option sir, then click the more recovery option then click the Go Back to Previous Build.
    2019-10-29T12:50:44+00:00
    same problem. I already formatted my hdd. the install clean windows 10. Then this error come out of nowhere 0x8007025D. ive had enough. lol
