Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2019-09-22T11:00:25+00:00
    I never did get mine repaired
    What I had to do was,I bought a sata/ide hard drive adaptor and a new hard drive. (USB 3.0 cheap under $40.00)
    I installed the new hard drive and then put to he old hard drive on to the adaptor
    Then I could access the old hard drive photos and documents and I transferred them to a memory stick
    Now all that being said, I am pretty upset with Microsoft,as I understand it the error is called a bug and a bug comes from their programmers.
    I am thinking hard about weather I am going to continue using Microsoft after this insane issue.
    They should have had a fix for this and NONE of the fixes offered worked for me. I ended up wiping out the old drive and then reselling the drive to recoup some of my money, but the time spent was insane
    2019-09-24T01:14:29+00:00
    Thank you for you reply and help
    2019-10-04T04:37:32+00:00
    I had this same issue and I FINALLY found a step that got me a bit further.
    Okay so I basically had the same problem, I tried to do a system retore, reset pc, as well as image boot but all were telling me it failed.
    I found these commands which have so far been the only help to advance any, I will update when confirmed to work.
    go to troubleshooting advanced option, then to commands and enter the following codes:
    net start vss
    hit enter button
    rstrui.exe/offline:C:\windows=active
    hit enter button
    now this will automatically pull up the systen restore option so you will be able to successfully restore your system to the last known good configuration.
    I have been stuck with this problem and just spent around 10 hours of researching. This is older code intended for Windows 7 but so far it's the only progress I have seen.
    I hope it works for me as well as you guys.
    Worth the try instead of completely having to reinstall to default/factory.
    2019-10-04T04:41:14+00:00
    net start vss
    hit enter button
    hit enter button
    Restore was unsuccessful -.-
    Now going to attempt another approach will update if it has any more progress.
