Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2019-08-08T20:49:45+00:00
    When you get to access denied is a dead end. Reformat the disc and start with a fresh Windows. It sucks, but there are no more solutions. Your disc my be the culprit too, if you can, change it for a SDD disc. It makes a huge difference.
    2019-08-08T21:14:19+00:00
    Oh my God
    what about my data is there any soulation ?
  3. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2019-08-09T04:48:23+00:00
    only BCD files are corrupted. so there is a way to recreate bcd boot files.  Don't format windows.
    search YouTube videos
    2019-08-09T07:11:46+00:00
    I have the same issue tried the boot ups but got access  denied on the 2nd one fixmbr
