Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
  1. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2019-06-05T01:58:45+00:00
    you have lost datas in the partition. very poor
    2019-06-05T02:07:24+00:00
    What? What would you do then
  3. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2019-06-05T09:55:06+00:00
    before reinstall or format of OS partition. I usually take image of Windows OS partition in the form of install.wim and then I saved that image install.wim into usb 64gbpendrive.
    That install.wim contains all dates and it can be extracted by 7 zip Software
    2019-06-05T10:17:23+00:00
    I use PC Dell OptiPlex 3060 , 3050 , 5050  .. Windows 10 .. 64bit more than 30 PC.
    I solve this problem from last year.. (more than 10 PC)
    I have Solution is use Dell Command : Update
    Dell Command : Update  is update Bios , all Drivers  ... It's work for me.
    I never see problem again. If you use Dell PC , Please try.
