Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2018-05-17T22:10:00+00:00
    Hey Steven i was just wondering if your computer is fixed from all of this.
    My pc has done the same thing and i can't seem to find a way to repair that works, it would be great if you could send some help.
    2018-05-23T14:32:24+00:00
    Hi Baldwin,
    Have you tried the troubleshooting steps provided by Janeane Cru? If the startup repair or fixing MBR does not resolve the issue, then might as well consider resetting your PC as Nick Dich suggested. Refer to this article for resetting your Windows PC.
    Let us know if you need further assistance.
    2018-06-01T20:08:03+00:00
    I typed in bootrec.exe/rebuildbcd and returned successfully scanned Windows installations.
    Total identified windows installations:1
    [1] d:\windows.old\Windows
    Add installation to boot list? Yes(y)/no(n)/all(a):
    What should I answer?
    2018-07-05T22:25:55+00:00
    All worked except fixboot i got access denied ?
