Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2019-05-18T17:43:38+00:00
    The fixboot command is not working it saying access is denied
    2019-06-04T21:52:02+00:00
    after I type boorec.exe /fixboot it comes back with Element not found.
    2019-06-04T22:34:45+00:00
    Hello All, I came back here to tel you I had to reinstall Windows 10 and it was all fixed. completely had to wipe the hard drive though, lost everything.
    2019-06-04T22:43:00+00:00
    Your gonna need to reinstall windows,  I tried pretty much everything, I was on a laptop so I had to install windows on a thumb drive
