Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2019-03-29T15:18:12+00:00
    GUYS
    I had this problem, and tried several things, and thought the problem would be from Microsoft, I realized that the problem was really on my ssd disk. The Disc was 70% Health. On an SSD disk this is not normal.
    If you have a SSD Disk check the Health with Hard Disk Sentinel
    2019-04-03T11:00:33+00:00
    I lost My all data
    And my CD drive not working after win 8.1 upgrading win10 possible go win 10 or win 8.1 is my inbiult  windows.....how can possible...?
  3. VARADHARAJAN K 9,726 Reputation points Volunteer Moderator
    2019-04-03T11:18:23+00:00
    initial windows 10 1809 released in October 2018 version deleted users datas
    2019-04-16T04:01:43+00:00
    Very sad for what happened to you. All my important data, I will put on the cloud.
