Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2019-03-13T19:21:08+00:00
    After using this last command it say's "Access is denied".
    So what shall i do now
    2019-03-23T15:22:29+00:00
    Windows 10 updated my computer last week and now I have the srttrail.txt problem that everyone else is posting about. Tried all except for reformatting. Is there a solution to this widespread problem?
    2019-03-25T20:05:46+00:00
    I mean really the reason I'm having the problem is from their updates now I can't fix my computer how do you keep from getting updates it's not the first time well I wish you luck if you figured out please let me know and thank you for replying Kathy
    2019-03-29T13:23:08+00:00
    I am experiencing the same problem as Steven but when i tried to run chkdsk /r c: it showed "Cannot open volume for direct access". What dies that mean? Can it be fixed? Thanks in advance!
