Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2018-01-17T13:43:45+00:00
    bcedit was not recognized as an internal or external command.
    I searched disabling the automatic repair via the command line and found: BCDedit /set recoveryenabled no. This operation was "completed successfully." However upon rebooting the computer the automatic repair was not disabled and I was not able to continue to windows in order to check the parameters you suggested and obtain the requested screen shot.
    2018-01-19T05:50:59+00:00
    Apologies for the typo. Are you using a desktop? We're planning to do a more in-depth troubleshooting however, we want to know other troubleshooting steps you've done aside from the above mentioned for us to avoid redundancy.
    2018-01-19T13:28:16+00:00
    I am not using a desktop. It is a Lenovo Thinkpad L540. I have not tried other troubleshooting steps.
    2018-01-21T07:57:11+00:00
    Okay, since the automatic repair didn't help you resolve the issue, we suggest that you perform a reset to your computer. Kindly visit the link provided here and follow the steps in resetting your PC. This link contains all the recovery options to help your computer get back in a working condition. The link is found here: Recovery options in Windows 10.
    Let us know if you need further assistance.
    If you think this was useful, you may "mark it as an answer" to help those who are facing the same concern.
