Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2018-11-14T07:54:13+00:00
    I'm sorry...but what annoys me here is not one person has asked the obvious question....
    Did you read that log file?
    I had the same issue and followed all the rest of the garbage posted here from many of the so called experts with no result...And then I used my brain and did the simple thing and read the log file.
    How did I read it and fix it? I downloaded a boot disk, there are many available on the internet, booted to a windows PE desktop, read the log file which told me there were 2 corrupted DLL files, copied the corrupted DLL's from an identical machine running the same version of Win 10 onto a USB and replaced the damaged files.
    One copied, the other gave access is denied, but windows booted on it's first boot and I was able to do what repairs were needed without reinstalling windows afresh.
    Admittedly I'm an IT guy with access to other computers and resources but even I don't know everything. Sometimes the simple answer fixes it fast. Boot disks come in many forms, I use one called Medicat but others like Hirens will do just as well. Make a bootable usb with one of these and in a worse case you will be able to copy all your files from your HDD before cleaning or reinstalling windows. If you don't have access to another identical source you can find the DLL's from the internet for download.....Hell...You can't break windows any more than it already is at the moment and at least you have your files.
    Microsoft has itself recognised that updates dating back as far as April 2018 have caused in very few cases this issue to happen. keep a bootable USB to hand.........You'll love it when things go seriously wrong, it won't fix a dead HDD but will let you retrieve documents and pictures if windows becomes a brick......
    Experts...Try suggesting the obvious.
    Happy computing guys and Gals!
    (how to make a bootable usb.... https://www.wintips.org/how-to-create-hirens-bootcd-usb-disk/)
    I actually did this myself and was able to get the PC back up and running. However, This did not solve the issue long term. The PC I did this on lasted about another week or two and it happened again.
    I sure hope it works for others better than it did for me! If anything, that'd give you enough time to get on, stay on long enough to back everything up then either hope it doesn't happen again or simply do a refresh/reformat.
    It is a recurring issue. That's probably the 3rd time that it happens to me using windows 10. Thankfully I managed to recover all my stuff from the hard drive using a recovery software. But my files and folders are all over the place. So I came to a comclusion that Windows 10 is unreliable especially on laptop that had previous version of Windows 10 before.
    2018-11-14T07:57:36+00:00
    This steps never worked for me. I had to make a bootable USB which also did not work. So I had to install a new copy of windows 10. But it is not a permanent fix as the issue is with windows 10 and not with the users. (That's what I believe unless proven otherwise)
    2018-11-21T20:35:19+00:00
    I have done what you said in the above and my pc now says this! Do i reset and see if it works now ?
    2018-11-23T17:30:48+00:00
    I've been having the same problems. Attached is a picture of the chkdsk results.
