Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2018-11-04T00:09:30+00:00
    From microsoft and google, it would seem a win 7 license would be required.
    per manufacturer, downloaded motherboard bios update onto flash drive. numerous you tube videos and attempts to bios taping or pressing from end to, f12 etc to no avail. Non computer savvy help  looked inside and said fan not turning and hit machine. It started with some error pop ups for fonts and saying restore not fully successful , etc.  I copied every last bit of data to flash drive.   I am now about to restart and see what happens.
    2018-11-11T03:38:22+00:00
    Fixed for now. All error messages gone. did uninstall Microsoft store solitaire and minesweeper.  windows Update shows last 50 definition updates failed to install.
    2018-11-11T09:06:49+00:00
    After doing so many command prompts I found the pro blemishes I think!
    Took a photo shoot .......Boot critical file C:\EFI\Microsoft\boot\resources\custom\bootres.dll is corrupt
    I am now at the end, don't know what to do next! Can anyone help please?
    2018-11-12T18:49:33+00:00
    I have typed bootrec.exe /fixboot
    Access denied
    what should i do ?
    Hi Steven,
