Automatic repair couldn’t repair your PC
2018-01-14T03:58:10+00:00
My computer wouldn't start and entered into an Automatic Repair. The automatic repair "couldnt repair [my]PC".
It specifies the following Log file: E:\Recovery\WindowsRE\Winre.wim\System32\Logfiles\Srt\SrtTrail.txt
*Modified title for accuracy*
*Original title: Automatic Repair Error SrtTrail.txt*
2018-01-14T09:38:16+00:00
Hi Steven,
This error occurs due to a possible corrupted startup file. For us to troubleshoot this issue, we suggest that you follow these steps:
  1. Restart your computer for 3 times to see Windows 10 Boot Options menu.
  2. Choose Troubleshoot.
3. Click on Advanced Options.
4. Select Command Prompt. 5. When Command Prompt appears, enter the following command lines and press Enterafter each: - bootrec.exe /rebuildbcd - bootrec.exe /fixmbr - bootrec.exe /fixboot 6. Restart your computer and check if the issue is resolved.
Let us know how it goes.
205 additional answers
    2018-01-14T14:17:40+00:00
    Thank you for you help. The problem was not resolved.
    bootrec.exe/rebuildbcd returned:
    "Successfully scanned Windows installations.
    Total identified Windows installations: 0
    The operation was completed successfully."
    bootrec.exe/fixmbr returned:
    "The operation was completed successfully."
    bootrec.exe/fixboot returned:
    "Access is denied."
    Upon restart the problem was not resolved.
