Bluetooth Keyboard PIN
2018-01-03T01:46:38+00:00
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair.   When I touch on the keyboard to pair and it asks for the pin.  I do not know the PIN and there is no default PIN for the device.  (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
    2023-01-04T07:48:49+00:00
    • yeajh youre the best
    2023-01-08T15:43:18+00:00
    Alison tq very much
    2023-01-09T03:23:55+00:00
    This is the solution 100% I have no idea why you are asked to reformat your phone or computer, it is absolutely unecessary for all of the hoops and hurdles. This solution is easy - just a few steps and it works.
    2023-01-19T18:48:33+00:00
    This worked for me too, except i have an older microsoft bluetooth explorer elite keyboard and I needed to enter an 8 digit pin and press enter on my keyboard. thanks for the solution!
    2023-01-31T03:12:15+00:00
    This was very helpful, as I am now typing with my bt keyboard. Ty
