Bluetooth Keyboard PIN
2018-01-03T01:46:38+00:00
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair.   When I touch on the keyboard to pair and it asks for the pin.  I do not know the PIN and there is no default PIN for the device.  (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
    2022-10-09T08:57:23+00:00
    I found solution for my keyboard... When it pops out to put PIN just tipe 4 digit number and click connect and then press the same 4 digit PIN code on your bluetooth keyboard and press enter/return
    Hope you found it useful. Please let me know.
    Wow mate you saved me from one big headache ha ha ha I can't believe it bloody worked first time ha ha ha after hours of utter uselessness from Microsofts end and wham you jump out with this one albeit 4 years ago ha ha.
    Aah so much stress relieved thank you very much:)
  2. Deleted
    2022-11-24T23:04:49+00:00
    i have tried that but all the default on don't work what do I do
    2022-11-24T23:14:55+00:00
    On your laptop keyboard enter any number and then click connect.
    Then on the bluetooth keyboard type the same number you entered and press enter / return
    Hope that helps
    2022-12-17T17:45:14+00:00
    17 Dec 2022. I applied your suggestion and it works. Thank you very much. -Andrew Chan, Singapore-
