Bluetooth Keyboard PIN
2018-01-03T01:46:38+00:00
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair.   When I touch on the keyboard to pair and it asks for the pin.  I do not know the PIN and there is no default PIN for the device.  (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
    2022-08-02T04:29:35+00:00
    Enter pin as 0000 then click on connect while it's showing connecting you need to enter same pin 0000 on you Bluetooth Keyboard and press enter from the Bluetooth Keyboard that tou pairing with windows... Hope it's helpful
    2022-08-03T07:43:45+00:00
    I've just tried and it worked, thank you so much!!!
    2022-08-15T13:08:32+00:00
    This one worked for me, didn't belive it was so easy, was exactly how you said it would work. Amazing thanks again.
    2022-08-22T14:39:46+00:00
    I had turned off a connected Dell bluetooth keyboard and when turning it back on the pairing was lost. Here is what worked for me:
    1. remove device from computer
    2. re-discover the device using the bluetooth search from computer
    3. The computer will issue a pin for you to enter on the bluetooth device to complete the set up. press enter at end of numbers.
    4. Done. it should reflect the device is paired and you can start using it.
    2022-08-28T00:11:16+00:00
    you are such an amazing tips been in trouble finding solution but i found it and it works ! great
