Bluetooth Keyboard PIN
2018-01-03T01:46:38+00:00
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair.   When I touch on the keyboard to pair and it asks for the pin.  I do not know the PIN and there is no default PIN for the device.  (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
    2022-04-19T19:57:53+00:00
    This is the only solution that worked for me
    Much obliged
    2022-04-20T14:09:00+00:00
    Surface keyboard will not connect ... when I enter the pin into the keyboard and hit enter it does not connect?
    2022-05-16T17:27:43+00:00
    life saver!
    I would never have guessed/imagined/think of entering the 0000 when it was processing the connection - whoever thought of this as a solution should be shot. Twice. In the kneecaps. :P
    Seriously, though, I was about to throw stuff out of the window! :)
    2022-06-29T02:27:41+00:00
    You are a genius
    It works 😀😀😀😀
    2022-08-01T12:31:58+00:00
    Thank you so much. This is the solution.
    It is incredible, that not even Microsoft support techs can give you this vital information.
    regards
    gkhar2
