Bluetooth Keyboard PIN
2018-01-03T01:46:38+00:00
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair.   When I touch on the keyboard to pair and it asks for the pin.  I do not know the PIN and there is no default PIN for the device.  (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
    2021-10-26T13:35:48+00:00
    Winner Winner Chicken Dinner! Thanks!
    2021-10-31T14:39:58+00:00
    I am having a similiar issue but did not know what the pin was for (there was nothing about a pin in the directions) so I did not copy it down, I tried the 0000 and 1234 thing but the original pin was 8 digits tried eight 0's nothing, got a pin on another device but that didn't work, now I cannot get another pin, is there an override through microsoft? I have deleted and added it several times just goes straight to asking for a pin.
    2021-11-16T13:39:22+00:00
    That worked a treat. Thank you!
    2021-12-02T21:47:30+00:00
    Brilliant! Worked perfectly!
    2021-12-19T02:52:56+00:00
    WOW. Worked a treat. Entered 9999 and it connected, Thanks.
