Gracias funcinó excelente !!!!
Gran ayuda
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair. When I touch on the keyboard to pair and it asks for the pin. I do not know the PIN and there is no default PIN for the device. (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
Gran ayuda
its not the 1234 or 0000 pin it just loads and never comnnecct
Entering "0000" or "1234" never works for me. I am sharing the way I used to re-pair my keyboard with my laptop.
man you are a life saver thanks bro
I was lost, your comment helped me, it really works.
