This worked! THANK YOU!
I pressed 1111, clicked enter on my original keyboard - then i clicked 1111 on my bluetooth keyboard and pressed enter while it was trying to connect and it actually did! Thank you for sharing this!
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair. When I touch on the keyboard to pair and it asks for the pin. I do not know the PIN and there is no default PIN for the device. (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
thank you!!! I was about to throw the whole lot out the window and smash up the house
Hahaha. I felt like that too!
Very Good, worked for me, Thank you
