I´m running windows 10 and that solution just worked. I´m typig this answer from the wireless keyboard right now. Amazing. thnx!
Bluetooth Keyboard PIN
Split from this thread.
I am having the same issue; namely, when I try to pair my keyboard (to a Win10 Mobile device) it sees the keyboard (Listing it as a "Bluetooth 3.0 Keyboard, Input") as available to pair. When I touch on the keyboard to pair and it asks for the pin. I do not know the PIN and there is no default PIN for the device. (I attempted to pair the Keyboard to an Android device, the Android device generated a new PIN and I entered that and it works with that device).
It appears that I need to wipe out the Win10 device's previous association with the BT keyboard so that I can start the pairing process again, but I cannot find any documentation on how to do that.
2019-07-14T16:21:11+00:00 -
2019-07-17T22:18:18+00:00 Para resolver este problema com o PIN, vai até o painel de controle, Dispositivos e impressoras, e clica em Adicionar um dispositivo:
Quando clicar em avançar também vai pedir o Pin, embaixo vai ter um link para digitar no aparelho, é só clicar, digitar e dar enter.
Não consegui o print pq já tinha me conectado :(
Att,
funcionou pra mim, parceiro! Obrigado!!!
2019-07-19T01:52:10+00:00 thank you bro
2019-07-23T11:57:12+00:00 In the last 24 hours, i have been scratching my head over this.
The above solution worked for me and i am giving this feedback on my BT mini keyboard. I had this Bakker Elkhuizen M-board 870 Bluetooth keyboard on Channel 1 with my laptop working till yesterday morning and After the updating to Windows 10, I experienced the similar issue as mentioned above, where the Laptop prompts for the PIN. I tried as the above and the it was not getting through. Eventually this is what brought my keyboard attached to the laptop.
- As mentioned i was on channel 1 of the keyboard for laptop. I decided to take this out.
I used my phone to pair the Keyboard on channel 1. i was able to type into my phone.
2. I used the connect press button on the backside of keyboard for the Laptop to detect the Blue tooth keyboard. Once i see
the detection of the device displayed on the laptop screen under "add Bluetooth device", i switched to channel 2 (using
host select +2).
- The laptop prompted for a PIN. I entered 0000 on the laptop keyboard and pressed the connect tab, As soon i see the entry
is taken
4. I entered the 0000 on the Bluetooth keyboard and press enter on the Bluetooth keyboard.
- Surprise surprise i see the the Keyboard connected under the Bluetooth device on the laptop.
To me this is weird and these products are flaky!!!! though it is working and i am using it now :-)
I dont know if this makes you happy or cry!!!!
2019-07-29T04:13:49+00:00 Hello, you just need to enter PIN in request window and next the same PIN on the keyboard and press Enter.
