whatsap instoll
Whatsapp ended support for all Windows Mobile phones on 31.12.2019. You cannot download or install Whatsapp on any Windows phone any more.
I am having Lumia 640 Dual with Windows 8.1.
I could not install WhatsApp latest version or even beta version from store.
It always stucks at “setting up whatsapp please wait” after phone verification
Really frustrating.
So far I tried
Any help is really appreciated.
whatsap instoll
Adding contact to Phonebook solved my problem. Thanks.
Thank you so much bro I made an account just to say thank you you helped me a lot!! I wish you all the best!
You will probably need to update your phone to windows 10. Look updated app in store and follow instructions. Can take awhile because you have to move apps over to SD card. Good luck ��
Wonderful !!!
After many tries and tenfold restarts / re-installs / accounts checking / you name what....
This was the ONLY problem: no contacts on my new phone yet.
I just added one contact and WhatsApp it worked!!!
Thank you so much.
***** 5 Stars
