Same here - WTF Microsoft.
Go to device manager - right click on video card - select properties - select rollback driver.
When I started my PC today Advanced Micro Devices, Inc. - Display - 7/25/2017 12:00:00 AM - 22.19.128.0 was installed by Windows Update. Since then, the maximum screen resolution available is 1280 * 1024 whereas it should be 1680 * 1050. See https://www.catalog.update.microsoft.com/Search.aspx?q=rx+580 for a listing of this update.
This driver should not have been installed as my AMD Radeon HD 4350 GPU is not supported by native drivers in Windows 10: http://support.amd.com/en-us/kb-articles/Pages/Driver-Support-for-AMD-Radeon%E2%84%A2-HD-4000,-HD-3000,-HD-2000-and-older-Series.aspx
However, there appears to be no way to remove this update as when I click on the Uninstall updates link in Windows Update, the new driver isn't listed.
How do I remove this driver, go back to the existing driver (version 8.970.100.9001 according to the article above), and prevent the "update" from being installed again?
Thanks!
Thank you! Thank You! Thank You!
This solved my problem!
You’re Welcome. Share the information with people you know who have the same problem.
It was frustrating for me as well and it me 2 days to figure it out. The information from this forum helped me as well.
i dont have a restore point i tried and i have none
anything i could do about my problem and thanks for your reply
Try restore from the option of using a system image. This is different than using a restore point, and all of your files will be saved that were in place on the date of the image. I did that and it worked. Then block automatic driver updates as described above.
Roll back the driver:
Device Manager>
Display Adapter>
Choose the main adapater (ATI, AMD, Intel Graphics, whatever you got) Right-click to open properties
Click "Driver" tap and select "Roll back driver' and that should do it.
It worked for my Dell Inspirion 1764 Windows 10 Pro x64
