Same here - WTF Microsoft.
Go to device manager - right click on video card - select properties - select rollback driver.
When I started my PC today Advanced Micro Devices, Inc. - Display - 7/25/2017 12:00:00 AM - 22.19.128.0 was installed by Windows Update. Since then, the maximum screen resolution available is 1280 * 1024 whereas it should be 1680 * 1050. See https://www.catalog.update.microsoft.com/Search.aspx?q=rx+580 for a listing of this update.
This driver should not have been installed as my AMD Radeon HD 4350 GPU is not supported by native drivers in Windows 10: http://support.amd.com/en-us/kb-articles/Pages/Driver-Support-for-AMD-Radeon%E2%84%A2-HD-4000,-HD-3000,-HD-2000-and-older-Series.aspx
However, there appears to be no way to remove this update as when I click on the Uninstall updates link in Windows Update, the new driver isn't listed.
How do I remove this driver, go back to the existing driver (version 8.970.100.9001 according to the article above), and prevent the "update" from being installed again?
Thanks!
Can you please tell me how you restored you computer back to normal after the 11/23/2017 (Advanced Micro Devices, Inc. - Display - 7/25/2017 12:00:00 AM - 22.19.128.0)
updated?
updated?
I can help you. I was having the same problem. Here's the SOLUTION:
Step 1: Go to Control Panel and click on Device Manger
Step 2: Scroll down and click on “Display Adapters” it’s going to dropdown and
click on ATI Mobility Radeon HD 42 Series.
Step 3: Wen the window open click on “Drivers” from the top tabs.
(This is where you will see the” Roll Back Driver”)
Step 4: Click on “Roll Back Driver”. Another window will pop up and give options to why you want to Roll Back or you can type in your answer.
Step 5: Click OK and within SECONDS your computer will be back to normal.
HERE’S THE SOLUTION
