Same here - WTF Microsoft.
Go to device manager - right click on video card - select properties - select rollback driver.
When I started my PC today Advanced Micro Devices, Inc. - Display - 7/25/2017 12:00:00 AM - 22.19.128.0 was installed by Windows Update. Since then, the maximum screen resolution available is 1280 * 1024 whereas it should be 1680 * 1050. See https://www.catalog.update.microsoft.com/Search.aspx?q=rx+580 for a listing of this update.
This driver should not have been installed as my AMD Radeon HD 4350 GPU is not supported by native drivers in Windows 10: http://support.amd.com/en-us/kb-articles/Pages/Driver-Support-for-AMD-Radeon%E2%84%A2-HD-4000,-HD-3000,-HD-2000-and-older-Series.aspx
However, there appears to be no way to remove this update as when I click on the Uninstall updates link in Windows Update, the new driver isn't listed.
How do I remove this driver, go back to the existing driver (version 8.970.100.9001 according to the article above), and prevent the "update" from being installed again?
Thanks!
Proper software should be AMD Catalyst for Windows 10 64-bit.
I would agree if AMD were supporting ATI 2000, 3000, 4000 series graphics but they're not. AMD only support Windows 8 on these ranges.
Microsoft say that they have now fixed the problem with the wrong drivers being updated by Windows Update.
See https://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/display-problems-on-some-amd-radeon-video-cards/037b84cc-2b3f-4192-aa51-83239bf1b61b for more information and the Microsoft's instructions to resolve the problem.
