Read this link and you know how to get rid of it.
https://appuals.com/fix-unknown-strange-devices-showing-network/
This is not really a security problem.
* Moderator note on Jan 2, 2021.
This old, long thread is being locked.
See posts by Steve-D-M on page 19 and by jamesdelwood on page 20.
The websites appuals.com and thewindowsclub.com may be recommending programs you shouldn't download or install. The information on the pages is safe, but the programs are often classified as PUPs (Potentiall Unwanted Programs.)
Original question:
I've got a random Amazon KFAUWI device showing up on my network as a device beside my driver for my router. Can anyone help? I am sure it is not a device in my house, as everything is set to something we've done or one of our names. Can anyone tell me if i'm stupid or if this is a general happening?
I tried a solution offered by
https://www.thewindowsclub.com/amazon-kfauwi-appeared-network-device
and it worked.
Briefly this is the procedure I used:
type in SERVICES.MSC in search then go to the right side and disable WINDOWS CONNECT NOW and that removed the annoying icon for me.
good luck
I found that it happens if Netlogon service is set to automatic or delayed automatic start-up.
YIPEEEEEEE!
