Ok this one took me a little while to fix.
The wife's PC uses blue tooth mouse and keyboard that suddenly stopped working one day. When i checked it had this exact same error that you have here. After following some of the posts that have replied to you and having no luck checked out the Intel website and installed their driver assistant app (https://www.intel.com.au/content/www/au/en/support/detect.html).
The intel assistant told me that the Bluetooth drivers were up to date but theWifidrivers where not - updating this driver instead actually fixed the error with the bluetooth
My theory for why this worked is that Wifi & Bluetooth appeared to be on the same chip so when the driver versions for each don't match we get these errors.
I hope this helps!
Thank you very much - this solved my problem which came after Windows update
