my HP still down. I already had .60 and upgraded to .70. un real how this issue has just been largely ignored.
Intel Wireless Bluetooth not working
I started my computer today and noticed I couldn't use my bluetooth devices. When I went to the Device Manager, I noticed my Intel Wireless Bluetooth was not working properly. The error message "This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE" displays in preferences. I've done the following already and still have the issue:
Disable and Enable the device
Check Windows update
Check device for updated driver software
Checked Intel for updated driver sofware
Run the Windows Bluetooth troubleshooter
Run the Windows Hardware and Devices troubleshooter
Uninstalled the device and driver software, rebooted and scanned for hardware changes to reinstall the device, reinstalled the driver software
I did that last one twice. The only thing I can get to happen is the device seems to cycle between "working properly" and the error message at least 20 times before finally deciding "This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE"
Moved from: Windows / Windows 10 / Network & internet
2018-08-15T13:18:04+00:00 -
2018-08-18T16:33:37+00:00 If you having a Bluetooth error code 10 after windows update here is something for you
I found a fix uninstalled ur Bluetooth driver, disable fast startup in power setting and then turn of your computer for 5 sec and turn it back on, Windows 10 will auto reinstall driver for you when your pc turn back on if not download the driver and install it urself. I believe fast startup doesn't turn off your pc completely when you restart or shut down and that's what costing the problem.
Credit does not go toward me, I found this somewhere else when I was searching on my phone but I forgot where.
and now I'm just sharing this everywhere because it was a pain for me when my Bluetooth didn't work after the windows 10 update and I try everything that internet has to offer but finally here something works
2018-08-26T05:08:14+00:00 If you having a Bluetooth error code 10 after windows update here is something for you
2018-09-08T20:26:26+00:00 I have the same problem as described above. 1 minute it was working fine,then I updated the Intel chipset driver and it stopped working.
2018-09-20T08:45:50+00:00 Ok this one took me a little while to fix.
The wife's PC uses blue tooth mouse and keyboard that suddenly stopped working one day. When i checked it had this exact same error that you have here. After following some of the posts that have replied to you and having no luck checked out the Intel website and installed their driver assistant app (https://www.intel.com.au/content/www/au/en/support/detect.html).
The intel assistant told me that the Bluetooth drivers were up to date but theWifidrivers where not - updating this driver instead actually fixed the error with the bluetooth
My theory for why this worked is that Wifi & Bluetooth appeared to be on the same chip so when the driver versions for each don't match we get these errors.
I hope this helps!
