Intel Wireless Bluetooth not working
2018-01-02T00:34:24+00:00
I started my computer today and noticed I couldn't use my bluetooth devices. When I went to the Device Manager, I noticed my Intel Wireless Bluetooth was not working properly. The error message "This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE" displays in preferences. I've done the following already and still have the issue:
Disable and Enable the device
Check Windows update
Check device for updated driver software
Checked Intel for updated driver sofware
Run the Windows Bluetooth troubleshooter
Run the Windows Hardware and Devices troubleshooter
Uninstalled the device and driver software, rebooted and scanned for hardware changes to reinstall the device, reinstalled the driver software
I did that last one twice. The only thing I can get to happen is the device seems to cycle between "working properly" and the error message at least 20 times before finally deciding  "This device cannot start. (Code 10) STATUS_DEVICE_POWER_FAILURE"
Moved from: Windows / Windows 10 / Network & internet
    2018-01-02T07:37:53+00:00
    No updates were installed from the time it was working to the time it wasn't. I am unable to install an older driver and the "rollback" button is not available to click.
    2018-01-02T05:28:30+00:00
    Thank you for sharing all the steps you have performed in order to fix the concern with Bluetooth driver.
    This issue may have been caused by some changes made in your computer. We'd like to know if you recently install any updates before the issue started and have you also tried rolling back the driver instead of using the latest driver? You may checked this **link**for the available Intel Wireless Bluetooth driver versions for Windows 10.
    We are looking forward to your response.
