I ran the Hardware and Device troubleshooter. It did say that there was a problem with my Bluetooth device, however after troubleshooting it was not able to find a solution for the problem. I also tried updating the Bluetooth driver, but according to Windows my driver is already up to date. I also downloaded the latest versions from Intel's website and from AS Rock (my motherboard manufacturer), but they are the same as what is already installed. It looks to me as if the driver is not the problem. Are there any other possibilities?
Thanks for the help.
Thank you for the updates.
For us to further check the issue, we'd like to know if you've tried performing the steps on how to troubleshoot Regsvr32 error messages. If so, what was the result? And can you also provide the update you've installed? To check, press Windows key + i > select Update & Security > click View installed update history.
We'll be waiting for your reply.
