Mine is Intel not AMD and i am comfertable to do Formating my SDD and reboot from USB, Any other suggessions?
How Do I Block 2018-01 Cumulative Update for Windows 10 Version 1709 for x64-based Systems (KB4056892)?
KB4056892 is Awaiting restart
Unfortunately, when I did a restart it bricked my system. I had a large windows logo on the screen and it just sat there. I rebooted and was able to trigger a repair. The repair said it was backing out the last update as it would not be completely installed.
With KB4056892 is Awaiting restart I did another restart and had the same problem. At the end I was staring at a Windows logo that just sat there.
Again I triggered a repair and the system is now usable. However, Windows Update still says: KB4056892 is Awaiting restart
How do I block it so it doesn't get installed if I have to reboot the machine?
2018-01-31T20:46:41+00:00 -
2018-02-01T07:16:56+00:00 My Notebook HP (window 10 home) as well. still unresolved last 30days despite following every instructions from Microsoft site.
2018-02-02T11:16:52+00:00 I'm now considering KB4058258 (OS Build 16299.214), apparently MS say:-
“Resolves the issue reported by some customers on a small subset of older AMD processors where the processor entered an unbootable state after installing January 3, 2018—KB4056892 (OS Build 16299.192
How do I install .214 on a PC that entered an unbootable state after KB4056892!!**!!
2018-02-02T16:22:36+00:00 Exactly! I had the cumulative update KB4058258 offered by Microsoft's Update & Security interface and the buggy KB4056892 no longer shows on wushowhide. I will say that Microsoft kept to their word on this patch.
You can rollback the buggy KB4056892 and go to the Microsoft Update Catalog to patch the fix.
2018-02-06T05:08:10+00:00 No problem! 😊
