How Do I Block 2018-01 Cumulative Update for Windows 10 Version 1709 for x64-based Systems (KB4056892)?
2018-01-05T07:42:12+00:00
KB4056892 is Awaiting restart
Unfortunately, when I did a restart it bricked my system. I had a large windows logo on the screen and it just sat there.  I rebooted and was able to trigger a repair.  The repair said it was backing out the last update as it would not be completely installed.
With KB4056892 is Awaiting restart I did another restart and had the same problem.  At the end I was staring at a Windows logo that just sat there.
Again I triggered a repair and the system is now usable.  However, Windows Update still says: KB4056892 is Awaiting restart
How do I block it so it doesn't get installed if I have to reboot the machine?
    2018-01-21T21:43:54+00:00
    So, in a couple years our processors might be useable again
    2018-01-21T21:45:08+00:00
    Sorry live chat is a machine and it did nothing for me.
    2018-01-22T01:16:50+00:00
    The 'Get Help' Live Chat app is a live representative however, after loading, I got this...
    2018-01-22T07:46:08+00:00
    Yes... Use the Get Help app. They will turn off the update for users who can't turn off the update themselves. All sorted here.
    2018-01-22T12:28:06+00:00
    Indeed! The 'Get Help' technical team at Microsoft will ask your permission for a 'remote access' if you are having problems turning off the updates via the MediaCreationTool.
