AWAY MICROSOFT!!! TELL US HOW TO BLOCK THIS OFFICIALLY! Instead of other users offering 3rd part solutions that for all we know could be dodgy. You know it's a problem!!!!!!!!!!!!
How Do I Block 2018-01 Cumulative Update for Windows 10 Version 1709 for x64-based Systems (KB4056892)?
KB4056892 is Awaiting restart
Unfortunately, when I did a restart it bricked my system. I had a large windows logo on the screen and it just sat there. I rebooted and was able to trigger a repair. The repair said it was backing out the last update as it would not be completely installed.
With KB4056892 is Awaiting restart I did another restart and had the same problem. At the end I was staring at a Windows logo that just sat there.
Again I triggered a repair and the system is now usable. However, Windows Update still says: KB4056892 is Awaiting restart
How do I block it so it doesn't get installed if I have to reboot the machine?
2018-01-10T22:40:49+00:00 -
2018-01-10T22:56:11+00:00 Other users are not offering third party solutions and the 'wushowhide' is taken from the Microsoft website. If you care to trust a few of us here who are trying to assist you with your problem, then you may learn something!
If you download the 'wushowhide' from this link: - http://download.microsoft.com/download/f/2/2/f22d5fdb-59cd-4275-8c95-1be17bf70b21/wushowhide.diagcab
you will get a window similar to this one, simply run it and block what ever update you like from Microsoft.
2018-01-10T23:14:55+00:00 When is Microsoft going to fix this update ? My W10 w/Intel ships...Automatic download continually takes place only to get the message "Download could not finish" afterwards.
2018-01-10T23:28:07+00:00 Go to your app folder and use the 'Get Help' app and you can talk to a live Microsoft technical support staff member. They will answer your questions.
The 'KB4056892' file has a bug that only affects mostly AMD chips however, it seems in rare cases such as yours, it also affects Intel chips as well.
Intel should be able to assist you also with your quest for a solution.
2018-01-10T23:55:48+00:00 My Intel was screwed.. no one would get it that it was an update not HP not Microsoft. Lost a weeks work redoing my system. The Windows 10 reset to factory keeping my personal files and losing my apps. It works now. I had to reload apps and programs. I should be reimbursed lost wages & delayed clients
