How Do I Block 2018-01 Cumulative Update for Windows 10 Version 1709 for x64-based Systems (KB4056892)?
2018-01-05T07:42:12+00:00
KB4056892 is Awaiting restart
Unfortunately, when I did a restart it bricked my system. I had a large windows logo on the screen and it just sat there.  I rebooted and was able to trigger a repair.  The repair said it was backing out the last update as it would not be completely installed.
With KB4056892 is Awaiting restart I did another restart and had the same problem.  At the end I was staring at a Windows logo that just sat there.
Again I triggered a repair and the system is now usable.  However, Windows Update still says: KB4056892 is Awaiting restart
How do I block it so it doesn't get installed if I have to reboot the machine?
    2018-01-09T13:55:58+00:00
    Because I have a memory capacity that was developed before the Internet was born I am reminded of an amusing episode with a Compaq Presario and XP's Service Pack 3 that occurred back in 2010.
    AMD really hasn't changed much. Which is probably why HP now uses Intel in their devices.
    https://support.hp.com/us-en/document/c01457284
    2018-01-09T18:40:09+00:00
    OK.  I paused Windows Updates but KB4056892 was still pending restart.
    Left the machine alone for a day and when I checked it today Windows Update said the machine was up to date.  Last checked 11:42 PM yesterday and  KB4056892 was gone.  Hide/show does not see it as hidden or as available.
    Now the question is: Is it safe to go back in the water and unpause Windows Update?
    2018-01-09T21:35:05+00:00
    Microsoft have now fully removed KB4056892 from their server. I ran the MediaCreationTool confirming the blocked update no longer existed on my system.
    You can all now rest with the knowledge your system boot will no longer 'hang' on startup.
    2018-01-09T21:37:34+00:00
    Had the same problems , finally fix it by going to settings , Update & Security , View installed update history , uninstall updates ... from there click on the update and then uninstall , wait for it to finish the uninstall and then reboot , then as soon as the system is rebooted run this http://download.microsoft.com/download/f/2/2/f22d5fdb-59cd-4275-8c95-1be17bf70b21/wushowhide.diagcab
     the update should be on the top of the list , then hide the update ... all done
    2018-01-09T21:39:33+00:00
    Yes, absolutely. I have just updated my W10 Pro and no problems to record...
