Technical team never mentioned Intel but I assume they are aware of all chipset manufacturers including ARM. It looks as though there is no quick fix for now at least.
How Do I Block 2018-01 Cumulative Update for Windows 10 Version 1709 for x64-based Systems (KB4056892)?
KB4056892 is Awaiting restart
Unfortunately, when I did a restart it bricked my system. I had a large windows logo on the screen and it just sat there. I rebooted and was able to trigger a repair. The repair said it was backing out the last update as it would not be completely installed.
With KB4056892 is Awaiting restart I did another restart and had the same problem. At the end I was staring at a Windows logo that just sat there.
Again I triggered a repair and the system is now usable. However, Windows Update still says: KB4056892 is Awaiting restart
How do I block it so it doesn't get installed if I have to reboot the machine?
2018-01-08T23:32:48+00:00 -
2018-01-08T23:33:42+00:00 Yes...What about Intel ?
2018-01-08T23:40:21+00:00 I did a reset.. lost all my apps. Still thinking that it will update at some point. I went to task manger - msconfig- and noticed that my start up in normal was unclicked.. and the launch button was greyed out
2018-01-08T23:46:02+00:00 If you had chosen F1 debugging *(with your W10 disk in)*you would have rolled back the incompatible update.
There were 10 option but F1 will not resolve the issue of rollback without the W10 disk.
2018-01-08T23:54:14+00:00 If you're waiting for a fix for your CPU why not install from
https://support.amd.com/en-us/download
instead of for them to send one through to Microsoft and get it there?
Advanced Micro Devices is not a division of Microsoft.
