Print job goes into queue and instantly disappears with nothing being printed
2017-11-16T20:31:55+00:00
For some reason my system has stopped working correctly with one of my printers. The system sees the printer as being connected and available and when I print the job goes to the print queue. However it then instantly disappears and nothing is printed. Can someone advise?
The printer with the problem is an Epson Stylus Photo 1290. The printer was working a couple of days ago and the only thing I can think that has happened is that there was an automatic windows update.
I am running Windows 10 Pro 64 bit version 15063.726
I have tried: starting and stopping the print spooler, uninstalling the driver, running the trouble shooter, rebooting ...
Any help welcome.
Chris.
Note: 28/11/2017 - I have had an email from Epson who confirm the problem is caused by a change introduced by Microsoft. As a result they have no fix for the problem and say that if I wish to continue using the latest version of Windows 10 then I need to buy a new printer or wait for Microsoft to introduce a change (which may never happen). This is hugely disappointing and is also not very environmentally friendly.
2020-02-28T19:18:13+00:00
Based on your post on printing, I think that the Microsoft Virtual Agent can help you troubleshoot your issue. It'll walk you through the right troubleshooting steps based on the specific problem you're facing.
Please let us know if this solved your issue.
78 additional answers
    2020-06-14T12:44:40+00:00
    Same here - Brother MFC-495CW.....just stopped worked. Same issues as this thread.
     Same here had to do some sort of update the other day and now my MFC 5890 wont work.  Im not very tech savvy either so very annoying !!!
    2020-06-14T13:29:17+00:00
    Suggestions anyone?
     Just wait for MS to come up with a solution. As they acknowledged the problem already, I think they are already on it & it shouldn't take long i.m.o.
    2020-06-14T13:41:07+00:00
    Read back through the thread! The solution (for the time being) is to remove the offending Windows update.
    2020-06-14T17:08:36+00:00
    Tx, I know that, but I had a reinstall of Windows before I saw that it was a problem with the update. So I can't roll back :( .
