Print job goes into queue and instantly disappears with nothing being printed
2017-11-16T20:31:55+00:00
For some reason my system has stopped working correctly with one of my printers. The system sees the printer as being connected and available and when I print the job goes to the print queue. However it then instantly disappears and nothing is printed. Can someone advise?
The printer with the problem is an Epson Stylus Photo 1290. The printer was working a couple of days ago and the only thing I can think that has happened is that there was an automatic windows update.
I am running Windows 10 Pro 64 bit version 15063.726
I have tried: starting and stopping the print spooler, uninstalling the driver, running the trouble shooter, rebooting ...
Any help welcome.
Chris.
Note: 28/11/2017 - I have had an email from Epson who confirm the problem is caused by a change introduced by Microsoft. As a result they have no fix for the problem and say that if I wish to continue using the latest version of Windows 10 then I need to buy a new printer or wait for Microsoft to introduce a change (which may never happen). This is hugely disappointing and is also not very environmentally friendly.
2020-02-28T19:18:13+00:00
Based on your post on printing, I think that the Microsoft Virtual Agent can help you troubleshoot your issue. It'll walk you through the right troubleshooting steps based on the specific problem you're facing.
Please let us know if this solved your issue.
78 additional answers
    2020-06-12T10:38:22+00:00
    I have a brother MFC-5890CN that will not print this morning after last nights update.
    I found it to be the Security Update for Adobe Flash Player. When I uninstalled that I was able to print PDFs again to my printer.
    2020-06-12T10:57:31+00:00
    Thanks, I had just done the same as you and its printing again..
    2020-06-12T11:56:23+00:00
    My MFC-5895cw the same. Can you walk me through how to uninstall that update please?
    2020-06-12T12:09:34+00:00
    Go to settings - update & security - view update history - uninstall updates
    This will bring you to a screen that lists all the recent updates
    Right click on the Security Update for Adobe Flash Player update and click uninstall.
    I then uninstalled the driver for my printer and re-installed this from the Brother website.
    Restarted and printer worked again! Hope that helps.
