Print job goes into queue and instantly disappears with nothing being printed
2017-11-16T20:31:55+00:00
For some reason my system has stopped working correctly with one of my printers. The system sees the printer as being connected and available and when I print the job goes to the print queue. However it then instantly disappears and nothing is printed. Can someone advise?
The printer with the problem is an Epson Stylus Photo 1290. The printer was working a couple of days ago and the only thing I can think that has happened is that there was an automatic windows update.
I am running Windows 10 Pro 64 bit version 15063.726
I have tried: starting and stopping the print spooler, uninstalling the driver, running the trouble shooter, rebooting ...
Any help welcome.
Chris.
Note: 28/11/2017 - I have had an email from Epson who confirm the problem is caused by a change introduced by Microsoft. As a result they have no fix for the problem and say that if I wish to continue using the latest version of Windows 10 then I need to buy a new printer or wait for Microsoft to introduce a change (which may never happen). This is hugely disappointing and is also not very environmentally friendly.
2020-02-28T19:18:13+00:00
Based on your post on printing, I think that the Microsoft Virtual Agent can help you troubleshoot your issue. It'll walk you through the right troubleshooting steps based on the specific problem you're facing.
Please let us know if this solved your issue.
78 additional answers
    2020-05-16T07:39:09+00:00
    I'm sorry but you're not going to like my answer. I never got the printer working again on Windows. I did get the printer working on a linux box I also run - this enabled me to print from windows (but via linux).
    2020-05-18T20:00:49+00:00
    2020-06-12T01:01:44+00:00
    I tried the troubleshooter posted on the thread - it did not work. I have a Brother MFC-495CW which was working fine up until today. The problem is as described at the beginning of this thread. I feel that it was a bad system update that caused the problem. Just have to figure out a way to roll them back and see which one. Microsoft if you are listening please help!
    2020-06-12T10:03:35+00:00
    I have a brother MFC-5890CN that will not print this morning after last nights update.
