Be careful with this. I couldn't wait and replaced the 68 with an 88 unit. When I locked the pci bus as a test, the 88 went incommunicado on the next boot; that was the only observed failure. Unlocking and then rebooting brought it back. So there are definite differences between the 88 and 68 in terms of how they behave as Windows manipulates the registers on the PCI bus -- or as whatever device driver Windows is using does this. Apparently the 88 driver has a problem with how Windows/driver implemented atomic operations. Thank you for the fix -- will try it out when I build my next Windows box.
Updated computer now Asus PCE AC68 will not work
I update to the latest version of windows 10 now my wireless network adapter will not work. I am currently use my iPhone usb hotspot to connect to the internet on my desktop. I have tried the latest driver updates and uninstalling and reinstalling. I have also tried a clean install. I have tried taking the Network adapter out and putting it back in. now I am stumped. I am getting error code 10. and when I try latest drivers it says that the latest drivers are already installed.
2017-12-30T21:02:31+00:00 -
2017-12-31T14:47:22+00:00 Hello.
I tried this suggested fix with a clean install of Windows 10 Fall Creators and it did not work. The same error appears in Device Manager.
Can anyone provide some additional detail? Are you using local or MS accounts? Was the driver installed before making the adjustment via msconfig or after? Did you install the latest driver or an earlier version? Did you install using the executable or by searching from within Device Manager for a local file? Did you run msconfig as Admin or as a user with admin privileges?
Any additional feedback appreciated. Thanks!
2017-12-31T17:42:31+00:00 Same for me here. Config didnt do it for me...
2018-01-02T17:10:02+00:00 It didn´t work for me...
2018-01-02T17:19:24+00:00 Agreed. I have tried this fix multiple times (in multiple ways) with clean installations of Fall Creators. Does not work.
My PC:
mobo: M5A99FX PRO R2.0
CPU: AMD FX-8370
memory: G.SKILL Ripjaws X Series 32GB DDR3 SDRAM DDR3 1866 (PC3 14900)
