Surface Pro 2017, Win 10 Pro x64: Explorer crash (Windows.UI.XamlHost.dll)
2018-01-04T03:56:25+00:00
Hi:
I have periodic explorer crashes on my Surface Pro 2017, Win Pro x64 (it is fully updated). The crash seems to occur periodically after a Hello Windows log-in (this occurs after the computer was sleeping rather than on a fresh boot). It seems to involve Windows.UI.XamlHost.dll based on the below.
When I look in the Event viewer I see errors like this:
Event ID 1000
Faulting application name: explorer.exe, version: 10.0.16299.125, time stamp: 0xfeba44fb
Faulting module name: Windows.UI.XamlHost.dll, version: 10.0.16299.15, time stamp: 0x00f27b8f
Exception code: 0xc0000409
Fault offset: 0x0000000000001db1
Faulting process id: 0x1880
Faulting application start time: 0x01d38282e4131af4
Faulting application path: C:\WINDOWS\explorer.exe
Faulting module path: C:\Windows\System32\Windows.UI.XamlHost.dll
Report Id: 6e835576-b35e-4d24-b6ce-331b05fa2c55
Faulting package full name:
Faulting package-relative application ID:
If I click on Start > type "view all" then click on "View all problem reports Control panel" the "Windows Explorer" "Stopped working" errors and then double click on one I would get something like this:
Source
Windows Explorer
Summary
Stopped working
Date
‎11/‎26/‎2017 10:53 AM
Status
Report sent
Description
Faulting Application Path: C:\Windows\explorer.exe
Problem signature
Problem Event Name: BEX64
Application Name: Explorer.EXE
Application Version: 10.0.16299.15
Application Timestamp: 66e02565
Fault Module Name: Windows.UI.XamlHost.dll
Fault Module Version: 10.0.16299.15
Fault Module Timestamp: 00f27b8f
Exception Offset: 0000000000001db1
Exception Code: c0000409
Exception Data: 0000000000000007
OS Version: 10.0.16299.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 2eb9
Additional Information 2: 2eb9591f0e04c7cfea277e3f34d3348f
Additional Information 3: 9333
Additional Information 4: 9333781589f3ec46cd357f0fda06eea0
Extra information about the problem
Bucket ID: 15f01e3e317a50b7b6bb92d1b9fc4f7c (116455065336)
I am at a loss to understand what the problem is here. I am glad to disable Hello Windows if this would end the problem. Thanks in advance for any help on this!
[Moved from: Windows / Windows 10 / Windows Hello, lock screen & sign-in]
    2018-01-30T00:23:58+00:00
    Apparently updating the graphics driver is not enough.
    Another crash: here is the dump file,
    https://1drv.ms/u/s!AoMjGh2ERllBaiZ2PDDQAc0k6AM
    I should add here are common things:
    • this happens after resuming from sleep but only when *not* plugged in
    • Edge browser is unresponsive and must be manually shut down via Task Manager
    You can try a repair on edge  .. Settings>> apps >>apps and features>>Find Microsoft Edge and click advanced options  then click repair.
    2018-01-30T12:36:03+00:00
    Thanks. Tried this but did not seem to do anything.
    If anyone can look at the dump and let me know if there is anything there please let me know.
    2018-01-30T15:47:01+00:00
    I found a thread relating to this error on another site. It would seem some of the fixes are more difficult than just doing a repair install of Windows.. I am sorry reading a dump file  is beyond my experience. Someone else will need to help on that. If you want to take a look at this thread maybe you will get an idea on what you can do. Ignore the post that looks like an ad for a program that fixes things.. Sorry can not be of more help.
    https://superuser.com/questions/1059411/windows-10-shellexperiencehost-crashes
    2018-01-30T16:05:35+00:00
    Thanks ConiGL I really appreciate the link!
    I will try a few of the suggestions there though I think my problem might be a bit different (there is a note about Windows.UI.Xaml.dll but it seems related to another application; honestly I have no clue I cannot really figure out ehat is going on here). Auggy has had some insights on the dump file, hopefully he can give it a look and see if there is a connection, of if he has other suggestions.
    Again thank you!
    2018-01-30T16:41:02+00:00
    Here is what I can see in my Crash Dump that I linked to above:
    FAULTING_IP:
    Windows_UI_XamlHost!wil::details::ReportFailure+e5
    00007ffe`8bbb1db1 cd29            int     29h
    EXCEPTION_RECORD:  ffffffffffffffff -- (.exr 0xffffffffffffffff)
    ExceptionAddress: 00007ffe8bbb1db1 (Windows_UI_XamlHost!wil::details::ReportFailure+0x00000000000000e5)
       ExceptionCode: c0000409 (Stack buffer overflow)
      ExceptionFlags: 00000001
    NumberParameters: 1
       Parameter[0]: 0000000000000007
    PROCESS_NAME:  explorer.exe
    ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application.  This  overrun could potentially allow a malicious user to gain control of this application.
    EXCEPTION_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application.  This  overrun could potentially allow a malicious user to gain control of this application.
    EXCEPTION_PARAMETER1:  0000000000000007
    NTGLOBALFLAG:  0
    APPLICATION_VERIFIER_FLAGS:  0
    FAULTING_THREAD:  000000000000159c
    BUGCHECK_STR:  APPLICATION_FAULT_STACK_BUFFER_OVERRUN_MISSING_GSFRAME_SEHOP
    PRIMARY_PROBLEM_CLASS:  STACK_BUFFER_OVERRUN_SEHOP
    DEFAULT_BUCKET_ID:  STACK_BUFFER_OVERRUN_SEHOP
    LAST_CONTROL_TRANSFER:  from 00007ffe8bbb1e09 to 00007ffe8bbb1db1
    STACK_TEXT:
    000000005f2ce220 00007ffe8bbb1e09 : 00005ef9219e0fc4 0000000000000000 0000000000000000 00007ffe8bbb9fd8 : Windows_UI_XamlHost!wil::details::ReportFailure+0xe5
    000000005f2cf760 00007ffe8bbc8d59 : 0000000017c382f0 000000001cb07d50 0000003700000011 000000001cefb330 : Windows_UI_XamlHost!wil::details::ReportFailure_Hr+0x39
    000000005f2cf7c0 00007ffe8bbc28fb : 0000000000000000 000000001cb088f0 000000002e768080 000000000000c000 : Windows_UI_XamlHost!wil::details::in1diag3::_FailFast_Hr+0x29
    000000005f2cf810 00007ffe8bbc946c : 000000001cefb640 0000000000000000 0000000000000000 0000000000000000 : Windows_UI_XamlHost!Microsoft::WRL::SimpleActivationFactory::ActivateInstance+0x34b
    000000005f2cf840 00007ffe9728d544 : 0000000000000000 0000000000000001 0000000000000000 0000000000000000 : Windows_UI_XamlHost!ASTAThreadHost::s_ASTAThreadHostStartThreadProc+0x6c
    000000005f2cf870 00007ffe97fe1fe4 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : SHCore!_WrapperThreadProc+0xc4
    000000005f2cf950 00007ffe9817efb1 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : kernel32!BaseThreadInitThunk+0x14
    000000005f2cf980 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : ntdll!RtlUserThreadStart+0x21
    FOLLOWUP_IP:
    SYMBOL_STACK_INDEX:  0
    SYMBOL_NAME:  Windows_UI_XamlHost!wil::details::ReportFailure+e5
    FOLLOWUP_NAME:  MachineOwner
    MODULE_NAME: Windows_UI_XamlHost
    IMAGE_NAME:  Windows.UI.XamlHost.dll
    DEBUG_FLR_IMAGE_TIMESTAMP:  f27b8f
    STACK_COMMAND:  ~236s ; kb
    FAILURE_BUCKET_ID:  STACK_BUFFER_OVERRUN_SEHOP_c0000409_Windows.UI.XamlHost.dll!wil::details::ReportFailure
    BUCKET_ID:  X64_APPLICATION_FAULT_STACK_BUFFER_OVERRUN_MISSING_GSFRAME_SEHOP_MISSING_GSFRAME_Windows_UI_XamlHost!wil::details::ReportFailure+e5
    WATSON_STAGEONE_URL:  http://watson.microsoft.com/00001db1.htm?Retriage=1
    Followup: MachineOwner
