I have the dump file and the issue may be with the Intel graphics as two components of the Intel graphics driver are referenced in the crash (igd10iumd64.dll and igc64.dll):
*** ERROR: Symbol file could not be found. Defaulted to export symbols for sppc.dll -
*** WARNING: Unable to verify timestamp for DropboxExt64.19.0.dll
*** ERROR: Module load completed but symbols could not be loaded for DropboxExt64.19.0.dll
*** WARNING: Unable to verify timestamp for igd10iumd64.dll
*** ERROR: Module load completed but symbols could not be loaded for igd10iumd64.dll
*** WARNING: Unable to verify timestamp for igc64.dll
*** ERROR: Module load completed but symbols could not be loaded for igc64.dll
GetUrlPageData2 (WinHttp) failed: 12002.
Probably caused by : Windows.UI.XamlHost.dll ( Windows_UI_XamlHost!wil::details::ReportFailure+e5 )
You could try updating the Intel graphics driver.
You may be able to use the latest version from Intel:
If not you may have to wait for an update to be pushed out from Windows Update.
The DropboxExt64.19.0.dll is also referenced in the crash but from the symptoms you described the issue is more likely the Intel graphics driver.
