I have exactly the same issue. Build 16299.192 on newest Surface Pro.
Surface Pro 2017, Win 10 Pro x64: Explorer crash (Windows.UI.XamlHost.dll)
Hi:
I have periodic explorer crashes on my Surface Pro 2017, Win Pro x64 (it is fully updated). The crash seems to occur periodically after a Hello Windows log-in (this occurs after the computer was sleeping rather than on a fresh boot). It seems to involve Windows.UI.XamlHost.dll based on the below.
When I look in the Event viewer I see errors like this:
Event ID 1000
Faulting application name: explorer.exe, version: 10.0.16299.125, time stamp: 0xfeba44fb
Faulting module name: Windows.UI.XamlHost.dll, version: 10.0.16299.15, time stamp: 0x00f27b8f
Exception code: 0xc0000409
Fault offset: 0x0000000000001db1
Faulting process id: 0x1880
Faulting application start time: 0x01d38282e4131af4
Faulting application path: C:\WINDOWS\explorer.exe
Faulting module path: C:\Windows\System32\Windows.UI.XamlHost.dll
Report Id: 6e835576-b35e-4d24-b6ce-331b05fa2c55
Faulting package full name:
Faulting package-relative application ID:
If I click on Start > type "view all" then click on "View all problem reports Control panel" the "Windows Explorer" "Stopped working" errors and then double click on one I would get something like this:
Source
Windows Explorer
Summary
Stopped working
Date
11/26/2017 10:53 AM
Status
Report sent
Description
Faulting Application Path: C:\Windows\explorer.exe
Problem signature
Problem Event Name: BEX64
Application Name: Explorer.EXE
Application Version: 10.0.16299.15
Application Timestamp: 66e02565
Fault Module Name: Windows.UI.XamlHost.dll
Fault Module Version: 10.0.16299.15
Fault Module Timestamp: 00f27b8f
Exception Offset: 0000000000001db1
Exception Code: c0000409
Exception Data: 0000000000000007
OS Version: 10.0.16299.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 2eb9
Additional Information 2: 2eb9591f0e04c7cfea277e3f34d3348f
Additional Information 3: 9333
Additional Information 4: 9333781589f3ec46cd357f0fda06eea0
Extra information about the problem
Bucket ID: 15f01e3e317a50b7b6bb92d1b9fc4f7c (116455065336)
I am at a loss to understand what the problem is here. I am glad to disable Hello Windows if this would end the problem. Thanks in advance for any help on this!
[Moved from: Windows / Windows 10 / Windows Hello, lock screen & sign-in]
2018-01-07T07:04:23+00:00 -
2018-01-08T05:20:13+00:00 I already tried the SFC.
The troubleshooting only turned on sleep for battery (which I have turned off since that crashes my Surface).
I need a specific suggestion. This is not very helpful.
PS Sorry Gerben that you have been having the same problems. This Surface has been exceptionally disappointing. I would not expect this level of instability from such a pricey machine (and one that Microsoft makes)
2018-01-08T15:01:49+00:00 Another explorer crash exactly like the previous ones.
Not sure if it is related but the Edge browser stopped a few hours before (though this did not happen most times I had an explorer crash):
via Start > type "view all" then click on "View all problem reports Control panel" the "Windows Explorer" "Stopped working" errors and then double click on one I would get something like this
Source
Microsoft Edge Content Process
Summary
Stopped working
Date
1/7/2018 10:42 PM
Status
Report sent
Description
Faulting Application Path: C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe
Problem signature
Problem Event Name: MoBEX
Package Full Name: Microsoft.MicrosoftEdge_41.16299.15.0_neutral__8wekyb3d8bbwe
Application Name: praid:ContentProcess
Application Version: 11.0.16299.15
Application Timestamp: 59cda7cd
Fault Module Name: EdgeContent.dll
Fault Module Version: 11.0.16299.125
Fault Module Timestamp: e5feec40
Exception Offset: 0000000000082243
Locale ID: 1033
Additional Information 1: fbbb
Additional Information 2: fbbbeb9e75b9a392bd0b19d9abee419b
Additional Information 3: f820
Additional Information 4: f820b8601cb36d2a94461cc926cdff30
Bucket ID: 8be98c36d855319a41b11e30cbf1228a (1274833364451402378)
I imagine this will never get resolved. Trying to figure out which is worse: Windows 10 or my Surface Pro 2017. Tough choice.
2018-01-08T15:40:33+00:00 Also from analysis of Edge minidump (MicrosoftEdgeCP.exe.mini.****.dmp):
FAULTING_IP:
EdgeContent!wil::details::ReportFailure+3d597
00007ffa`e4722243 cd29 int 29h
EXCEPTION_RECORD: ffffffffffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 00007ffae4722243 (EdgeContent!wil::details::ReportFailure+0x000000000003d597)
ExceptionCode: c0000409 (Stack buffer overflow)
ExceptionFlags: 00000001
NumberParameters: 1
Parameter[0]: 0000000000000007
PROCESS_NAME: MicrosoftEdgeCP.exe
ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_PARAMETER1: 0000000000000007
NTGLOBALFLAG: 0
APPLICATION_VERIFIER_FLAGS: 0
FAULTING_THREAD: 0000000000004cc4
BUGCHECK_STR: APPLICATION_FAULT_STACK_BUFFER_OVERRUN_MISSING_GSFRAME_SEHOP
PRIMARY_PROBLEM_CLASS: STACK_BUFFER_OVERRUN_SEHOP
DEFAULT_BUCKET_ID: STACK_BUFFER_OVERRUN_SEHOP
LAST_CONTROL_TRANSFER: from 00007ffae46e4ca4 to 00007ffae4722243
STACK_TEXT:
000000f0
51efe8b0 00007ffae46e4ca4 : 0000000000000000 00007ffae46a7270 0000000000000000 0000000000000000 : EdgeContent!wil::details::ReportFailure+0x3d597000000f0
51effdf0 00007ffae4702509 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : EdgeContent!wil::details::ReportFailure_Hr+0x44000000f0
51effe50 00007ffae472319e : 0000022a13c2be20 0000000000000000 0000000000000000 0000000000000000 : EdgeContent!wil::details::in1diag3::FailFast_Hr+0x29000000f0
51effea0 00007ffb061e1fe4 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : EdgeContent!`anonymous namespace'::MemoryLimitWatchdogThreadProc+0x3b43e000000f0
51efff30 00007ffb08d6ef91 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : kernel32!BaseThreadInitThunk+0x14000000f0
51efff60 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : ntdll!RtlUserThreadStart+0x21FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: EdgeContent!wil::details::ReportFailure+3d597
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: EdgeContent
IMAGE_NAME: EdgeContent.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 0
STACK_COMMAND: ~4s ; kb
FAILURE_BUCKET_ID: STACK_BUFFER_OVERRUN_SEHOP_c0000409_EdgeContent.dll!wil::details::ReportFailure
BUCKET_ID: X64_APPLICATION_FAULT_STACK_BUFFER_OVERRUN_MISSING_GSFRAME_SEHOP_MISSING_GSFRAME_EdgeContent!wil::details::ReportFailure+3d597
WATSON_STAGEONE_URL: http://watson.microsoft.com/00082243.htm?Retriage=1
2018-01-08T20:01:54+00:00 Based on the analysis that you've provided, the cause of the crash is different. To isolate if this is caused by a corrupted user profile, it is better to create a new user account and check if the crash occurs. Click this link on how to create a local user or administrator account in Windows 10.
Keep us in the loop with the result.
